Top App Bar
axTopAppBar
axTopAppBar allows a push button to be inserted into the 5250 screens. Top App Bars are a container for items such as application title, navigation icon, and action items.
actionItems |
The action items which are place on the opposite side of the navigation menu icon |
Yes. Must return an array. |
None |
drawerItems |
The drawer items which are place on the drawer side navigation. |
None |
drawerType |
Indicates the variants of drawer type to use. The values are Modal Drawer, Dismissible Drawer and Permanent Drawer. |
Modal Drawer |
enable5250Menu |
When enabled the 5250 menu items will be available on drawer side navigation. |
Enabled |
onActionSelection |
Optional. JavaScript code to be executed when an action item is clicked. |
None |
onDrawerSelection |
Optional. Javascript code to be executed when a drawer item is clicked. |
None |
title |
Specifies the title or caption of topAppBar. |
Yes. Must return a string. |
None |
Warnings
This extension is available only in material design theme. This extension is almost similar in functionality and usage to checkbox extension. See axCheckbox extension for more example usage and replace checkbox with axSwitch.
Example 1:
Selection Application in the Extendable objects then drag and drop topAppBar extension from the extension toolbox to the design screen grid. Make sure you are on design screen mode.
Extension Property: (Modal Drawer)
Rendered on Screen:
Extension Property: (Dismissible Drawer)
Rendered on Screen:
Extension Property: (Permanent Drawer)
Rendered on Screen:
