Simple Box
axSimpleBox
axSimpleBox allows a simple box to be inserted into the 5250 screen.
style |
Additional style properties that should be applied to the <div> container of the label. |
Yes. Must return a valid style object. |
None. |
When JQueryUI is selected from Application->Styling->appStylesTheme property, the display will change according to the theme that was set in the Application’s jqueryTheme property. Basically, the default border and the font styles will be based on the JQuery theme.
If this is used as style and the box is sized and located ….
border:1px solid red;background:buttonface;
it should produce a display like this when used on the IBM i main menu …
background:orange;
it should produce a display like this on the IBM i main menu …
