axMultitypeInputbox
Allow a user add an HTML input element which can be text, color, email, file, number, password or url.
Also included in this eXtension is the Japanese Kana conversion function with the Furigana input type.
eXtension properties vary depending on the selected input type.
Properties when Text (default) is selected as inputType:
Indicates whether this element is enabled.
TS2 only.
Yes. Must return a Boolean.
True
helpertext
The helper text provides supplemental information to users.
For Material Design theme only.
Yes. Must return a String.
None
helpertextStyle
CSS properties to be applied to helpertext or validation message of this eXtension.
Yes. Must return a valid style object.
None
icon
The name of icon to display.
None
iconPosition
Specify whether to display the icon as leading or trailing. The values are Left Position and Right Position.
Left Position
iconStyle
CSS properties to be applied to icon.
None
inputType
List of input elements that can be selected. Current values are Color, Email, File, Furigana, Number, Password and URL. Text is the default value when none is selected.
None
labelStyle
CSS properties to be applied to label (placeholderText).
None
onBlur
Optional. JavaScript code to be executed when the element loses the focus.
None
onChange
Optional. JavaScript code to be executed when the value changes.
None
onFocus
Optional. JavaScript code to be executed when the element receives the focus.
None
onPrompterClick
Javascript code to be executed when the user clicks on the prompter button.
SENDKEY('F4');
onScreenReady
Optional. JavaScript code to be executed every time layout render of all extension is completed.
None
pattern
The regular expression to check against the value of this extension.
Blank
placeholderText
The text to be displayed as a short hint for this extension.
In Material Design theme, it also acts as the label.
None
prompter
Indicates whether to add a prompter to this extension.
False
required
Indicates whether this extension must be filled up.
False
CSS properties to be applied to the eXtension.
None
textFieldStyle
Specify the appearance of the multitype input box extension as a TextField object. The values are Standard and Outlined.
Standard
value
Indicates the initial value of the input element.
None
validationMessage
The message to replace the default validation message.
None
Back to top
Properties when Color is selected as inputType:
TS2 only.
True.
inputType
Color
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
None
textFieldStyle
Standard
value
Indicates the initial value of the input element. The value must be a hexadecimal color code, usually starts with “#”. (e.g. #BFAA8F). When invalid color code is set, the browser will display black as the default color.
#000000
Back to top
Properties when Email is selected as inputType:
TS2 only.
True.
helpertext
None
helpertextStyle
None
icon
None
iconPosition
Left Position
iconStyle
None
inputType
List of input elements that can be selected. Current values are Color, Email, File, Furigana, Number, Password, and URL. Text is the default value when none is selected.
Email
labelStyle
None
maxLength
The maximum number of characters allowed. By default, this is set to the standard Javascript maximum value.
524288
multiple
When enabled, multiple email entries can be set in a form of comma-separated values.
False
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
pattern
None
placeholderText
None
required
None
None
textFieldStyle
Standard
validationMessage
None
value
None
Back to top
Properties when File is selected as inputType:
TS2 only.
True
helpertext
None
helpertextStyle
None
icon
folder_open
iconPosition
Left Position
iconStyle
None
inputType
No.
File
labelStyle
None
multiple
When enabled, multiple file selection is possible; otherwise only a single file can be selected.
False
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
required
False
None
textFieldStyle
Standard
type
Indicates the file type filter. Possible values are All, Audio, Image, Video.
All
validationMessage
None
Back to top
Properties when Furigana is selected as inputType:
TS2 only.
True
helpertext
None
helpertextStyle
None
icon
None
iconPosition
Left Position
iconStyle
None
inputType
Furigana
kanaStyle
CSS properties to be applied to the Kana output portion of the eXtension.
None
kanaType
Either Hiragana or Katakana.
Hiragana
labelStyle
None
nameCaption
A string of characters which stands as the label of the Kana input portion.
名前
nameStyle
CSS properties to be applied to the Kana input portion of the eXtension.
None
placeholderText
Blank
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
showCaption
When enabled, the name and label captions will be shown. Otherwise they are hidden.
True
textFieldStyle
No.
Standard
Back to top
Properties when Number is selected as inputType:
TS2 only.
True
helpertext
None
helpertextStyle
None
icon
None
iconPosition
Left Position
iconStyle
None
inputType
Number
labelStyle
None
maxNum
Maximum value that can be set.
10
minNum
Minimum value that can be set.
0
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
placeholderText
None
required
False
step
Unit scale for each increment or decrement.
1
None
textFieldStyle
Standard
validationMessage
None
value
0
Back to top
Properties when Password is selected as inputType:
Enabled
TS2 only.
True
helpertext
None
helpertextStyle
None
icon
None
iconPosition
Left Position
iconStyle
None
inputType
Password
labelStyle
None
maxLength
524288
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
pattern
None
placeholderText
None
required
False
None
textFieldStyle
Standard
validationMessage
None
value
None
Back to top
Properties when URL is selected as inputType:
TS2 only.
True
helpertext
None
helpertextStyle
None
icon
None
iconPosition
Left Position
iconStyle
None
inputType
URL
labelStyle
None
onBlur
None
onChange
None
onFocus
None
onScreenReady
None
pattern
None
placeholderText
None
required
False
None
textFieldStyle
Standard
validationMessage
None
value
None
Back to top
This eXtension works only in the advanced terminal emulator (TS2) and is not intended to be run in the basic terminal emulator (TS1).
The eXtension properties will be updated automatically according to the selected input type.
To dynamically read the value of the eXtension in a script, use the code:
FIELDS( <base name> ).getProperty( “value” );
Where <base name> is the value of the “name” property under the “Basic”, sub-pane of the “eXtensions” pane in TS2 Developer.
That is, the code is applicable for all the given input types except for the Furigana type. To get the values for of the two input elements in the Furigana eXtension, use this code:
GETKANAVALUE1( <base name> );
GETKANAVALUE2( <base name> );
GETKANAVALUE1 is a common user function that retrieves the value of the Kana input element. GETKANAVALUE2 is also a common user function that retrieves the value of the Kana output element.
When the input type is File, the file object list associated with the files selected by this extension can be retrieved using the following code:
GETFILES( <base name> );
GETFILES is a common user function that retrieves the array of File objects set in this extension.
The value of placeholderText property displayed in this extension has a fixed style color of #999. Even if this extension’s style->color property is set to another color, the display of the placeholder text will not be affected.
Color input type is not supported in IE/Edge.
Each of the input types, depending on the input restrictions set, is automatically validated as the user types the value.
In case of invalid value, an error icon is displayed at the right side of the input box. When the mouse is hovered on the error icon, the browser’s built-in message is displayed as follows:
IE 11 is used in the above image.
Please note that the error message is browser-dependent.
But this message can be customized by setting a value to validationMessage property.
In addition, when this extension is added to an aXes input field that needs to be posted and it contains input validation error, a message will display on the status bar as follows and the screen will not be posted:
When prompter property is checked, an ellipsis will be attached to the field as follows:
When the user clicked on the ellipsis, the Javascript code defined in onPrompterClick property will be executed. The default is to send the F4 key for prompt.
When jQueryUI is selected from appStylesTheme property of the Application, the display will change according to the theme that was set in the Application’s jqueryTheme property. Basically, the default border and the font styles will be based on the JQuery theme.
In Application, appStylesTheme property = Material Design
When Material Design is selected from appStylesTheme property of the Application, the display will change according to the theme that was set in the Application’s mdTheme property.
In Material Design theme, the Multitype Input Box extension is displayed as a Text Field component. The value in placeholderText property acts as the label of the eXtension.
Below are examples how this eXtension is displayed:
  Properties to set Initial Display  When this eXtension is focused or a character is typed
1
inputType: <default>
placeholderText: Name
2
helpertext: Full name
icon: person
3
textFieldStyle: Outlined
icon: person
iconPosition: Right Position
4
inputType: File
placeholderText: Select a file to upload
5
inputType: Furigana
6
inputType: Number
placeholderText: Input a number
maxNum: 10
minNum: 1
validationMessage: 1-10 only
When input is invalid:
Back to top
