axButton
axButton allows a push button to be inserted into the 5250 screen.
buttonType
The type of Material Design button to apply. The values are text, raised, unelevated, outlined, and dense.
For Material Design theme only.
unelevated
caption
Specifies the text that is to appear on the button.
Yes. Must return a string.
None
Indicates whether this element is enabled.
TS2 only.
Yes. Must return a Boolean.
True
hidden
Indicates whether this button is hidden or visible.
False
icon
The name of icon to display on the button.
None
onClick
Optional. JavaScript code to be executed when the user clicks on the button.
SENDKEY(ENV.defaultKey);
onFocus
Optional. JavaScript code to be executed when the element receives the focus.
None
onBlur
Optional. JavaScript code to be executed when the element lost the focus.
None
Additional style properties that should be applied to the button.
Yes. Must return a valid style object.
None
sizeToField
Indicates whether this button should be sized to fill its containing field or automatically sized to match its content.
True
tooltip
The tool tip (or hint) that should appear when the user hovers the mouse over this button.
None
In Application, appStylesTheme = JQueryUI
When JQueryUI is selected from Application->Styling->appStylesTheme property, the display will change according to the theme that was set in the Application’s jqueryTheme property.
Basic display:
When JQueryUI theme is selected:
Hovering on the button will also change its styles.
In Application, appStylesTheme = Material Design
When Material Design is selected from Application->Styling->appStylesTheme property, the display will change according to the theme that was set in the Application’s mdTheme property.
When buttonType property is set to unelevated (default):
When buttonType property is set to text:
Image       when hovered:   Image
When buttonType property is set to raised:
When buttonType property is set to outlined:
When buttonType property is set to dense:
When icon property is set to save:
(1). On the System i Main Menu, with the command input field named Commandline, if this push button is added to the display:
with this onClick code:
FIELDS("CommandLine").setValue("WRKOUTQ QPRINT");
SENDKEY("Enter");
then clicking on the button will cause the output queue QPRINT to be displayed.
(2). On the System i Main Menu turn the function key strings Fn=xxxx into buttons:
Click on F3=Exit to select it.
In the extensions list, select Push Button and F3=Exit should turn into a button with a caption of Exit:
Size the button as required and repeat for other desired function keys:
Using Screen Customization to Add Value
Using Scripting in Properties to Add Value
Push Buttons in Tutorial 6 - Advanced Screen Enhancement
Using Multilingual Captions on Buttons (and other places) in Tutorial 6 - Advanced Screen Enhancement
Using alert()
