axHTML
axHTML allows a raw HTML string to be inserted into a 5250 screen.
html
Specifies a string or JavaScript code that defines the HTML element definition(s) to be inserted into the screen. For example: <div>Hello</div> or <table><tr><td>123</td></tr><tr> td>456</td></tr></table>.
Yes. Must return a string.
None.
onScreenReady
JavaScript code that is to be executed every time layout render of all extension is completed.
None
Additional style properties that should be applied to the <div> container of the HTML elements defined by the html property.
Yes. Must return a valid style object.
None.
None.
This simple string …
<p style="color:red;font-size:48pt;">Hello World</p>
should produce a display like this …
This executable JavaScript …
var oDate   = new Date();
var sResult = "<div>Time is " + oDate.getTime().toString() + "</div>";
ENV.returnValue = sResult;
Specify this code in the onScreenReady property:
TRACE("**** MY ONREADY CODE IS EXECUTING. ****");
Now execute your aXes application with trace mode turned on.
You should see trace statements indicating that your code has been executed.
