Simple Line
axSimpleLine
axSimpleLine allows a simple line to be inserted into the 5250 screen.
orientation |
The intended orientation of the line. Specify as horizontal or vertical. |
Yes. Must return "H" or "V". |
Horizontal |
lineStyle |
The style of the line. Specify as dotted, dashed, solid or double. |
Yes. Must return "dotted", "dashed", "solid" or "double". |
Solid |
lineColor |
The color of the line. Must be a valid HTML color. For example: Green or #FFF5F6. |
Yes. Must return a valid color. |
Black |
lineThickness |
The thickness of the line in pixels. Must be specified as Npx where N is in the range 1 to 256. |
Yes. Must return a valid thickness string in format "Npx". |
1px |
When JQueryUI is selected from Application->Styling->appStylesTheme property, the display will change according to the theme that was set in the Application’s jqueryTheme property. Basically, the default border and the font styles will be based on the JQuery theme.
In Application, appStylesTheme property = Mayerial Design
When Material Design is selected from Application->Styling->appStylesTheme property, the display will change according to the theme that was set in the Application’s mdTheme property.
If these properties are used and the line is sized and located ….
orientation |
Horizontal |
lineStyle |
Solid |
lineColor |
Green |
lineThickness |
2px |
it could produce a display like this on the IBM i main menu ….
orientation |
Vertical |
lineStyle |
Dashed |
lineColor |
Red |
lineThickness |
8px |
