axButtonMenu
Allows a button with a menu to be inserted into the 5250 screen. Menus display a list of choices on a transient sheet of material.
buttonType
Specifies a material design button style to apply No unelevated
caption
Specifies the text that is to appear on the button. Yes. Must return a string. None
icon
Specifies a name of icon to display Yes. Must return a string None
items
Specifies the caption(s) of the item(s) to appear on the menu Yes. Must return a string
menuPosition
Display location of the menu relative to the button Yes. Must return a string Bottom Start
onItemSelection
Javascript code to be executed when user click on the menu item Yes None
sizeToField
Indicates whether this button should be sized to fill its containing field or automatically sized to match its content. Yes. Must return a string. True
tooltip
The tool tip (or hint) that should appear when the user hovers the mouse over this button. Yes. Must return a Boolean. None
Indicates whether this element is enabled. Yes. Must return a Boolean. True
This extension is available only in material design theme.
(1). A button Menu with 3 items and separator.
Modify the following Extension property:
  • icon property: menu
  • items property: add 3 entries for menuType and caption sub property
  1. List Item, Upload
  2. List Item, Download
  3. Separator, leave this caption blank.
  4. List Item, Exit
Icon property
The icons that you can use is based on the localized version (shipped with axes) of google material design icon (web fonts). See https://material.io/tools/icons/?style=baseline for the list of icons.
