Extension Tutorial 6 - Advanced Screen Enhancements v4.2.2
About this tutorial
Objectives |
This tutorial teaches you how to customize 5250 screens by moving, hiding, and adding screen elements using aXes eXtensions including dates, dropdown lists, group boxes, hyperlinks, images, push buttons, and radio buttons. |
Prerequisites |
Tutorial 5 – Basic Screen Enhancement Before attempting this tutorial, please complete all of the steps in Tutorial 5. |
Outline |
What this tutorial covers Screen and field names What’s the plan? Getting assistance Setting up your styles Defining styles Why are styles important? Adding a stripe Moving elements, changing labels and captions Move and resize screen elements Hiding screen elements Applying styles Tooltips Dates Radio buttons Drop down lists Using row and other scripting objects Push buttons Multi-lingual text Group boxes Images Hyperlinks Finish the screen customization Testing customizations |
This tutorial focuses on customizing this 5250 screen:
By the end of the tutorial, you will be able to make it look and act like this:
The screen customization includes these areas of visual customization and functional enrichment:
Features |
Tutorial Topics |
Styles and styling |
Defining and using styles. How to style screen elements by their role. |
Moving, hiding, and enhancing |
Understand how to move things around the screen. Hide and alter screen content. Use tooltips (hints) as a substitute for long labels. |
Group Boxes |
Use group boxes and stripes to visually group and draw attention to information. |
Radio Buttons |
How to use radio buttons. |
Dates |
How to change the way that dates are displayed and adding calendar pickers. |
Drop Downs |
How to add drop downs or combo boxes. |
Images |
How to add images. |
Hyperlinks |
How to add hyperlinks to display associated information. |
Buttons |
How to add buttons and script what happens when users click them. |
This section defines screen and field names used in all tutorials.
You don’t have to read this section just now. It is a reference point for this and the following tutorials.
The screens are XHRRPGTRN_Select and XHRRPGTRN_Maint.
You can display the screens by adding AXESDEMO to your library list and then calling the program XHRRPGTRN.
XHRRPGTRN_Select and its field names
This is the XHRRPGTRN_Select screen, with its fields named as indicated:
XHRRPGTRN_Maint and its field names
This is the XHRRPGTRN_Maint screen, with its fields named as indicated:
What’s the plan?
It’s important to have a 5250 screen customization and enhancement plan. Creating a plan will ensure that the look and feel of the screens remain consistent after customization, and help you to allocate a priority to the screens you intend to customize – work on the most important screens first.
In this tutorial, the plan is to customize this 5250 screen:
The customization will add these visual and functional eXtensions to the screen: styles, a stripe, date pickers, a radio button, drop downs, buttons, group boxes, an image, and hyperlinks.
The outcome of the customizations will look like this screen.
Getting assistance
While completing these tutorials you can get information from the product documentation. This is a sample page from the eXtensions Guide.
The aXes Technical Documentation Index provides a list of the documents.
Up until now, you may have used one of the shipped basic 5250 themes, e.g. blue or default, to change the appearance of your aXes 5250 application.
In the aXes Developer window, click Application in the Extendable Objects list to view the application properties. No need to put it in edit mode, it is already editable.
Locate the Styling bar at the bottom of the aXes Developer window.
Click on the Edit Items button adjacent to the styles label.
aXes will display the Edit Items window. Click the delete icon in the first column to remove the default styles.
Click on the plus button [+] to add a style item.
Use the following property values for the background style.
BasicWindowBackground |
styleFor |
Application Window |
htmlTag |
style |
theme |
for5250Attributes |
Click the Edit Styles button in the style property.
Input the following into the Edit Styles window, then click OK.
background: #9cc1e5 url('/ts/skins/images/bluebgimg.jpg') repeat-x top left
This will set the image (bluebgimg.jpg) as the screen background.
Next, add the font, key information, and screen title styles.
Click on the plus button [+] to add an item for the font style.
Use the following property values for the font style.
BasicFont |
styleFor |
All |
htmlTag |
style |
Click the Edit Styles button, input the following into the Edit Styles window, then click OK. font-family:Verdana font-size:9pt |
theme |
for5250Attributes |
Click on the plus button [+] to add an item for the key information style.
Use the following property values for the key information style.
KeyInformation |
styleFor |
htmlTag |
style |
Click the Edit Styles button, input the following into the Edit Styles window, then click OK. color:blue |
theme |
for5250Attributes |
Click on the plus button [+] to add an item for the screen title style.
Use the following property values for the screen title style.
ScreenTitle |
styleFor |
htmlTag |
style |
Click the Edit Styles button, input the following into the Edit Styles window, then click OK. font-style:italic |
theme |
for5250Attributes |
When you finish adding the styles the Edit Items window should look like this:
Click the OK button to close the Edit Items window.
Click Save button to apply the changes.
To see the effect of your styles:
Sign off from your aXes development session.
Close the browser window.
Start your aXes development session again.
You should see the result of the BasicWindowBackground style.
You define styles so that screen elements can be quickly associated with their visual display characteristics or rules, e.g. all screen titles are to be displayed in italics, and screens will have a blue background.
Styling is a sophisticated feature and there is another tutorial dedicated to styling.
The benefits of using styles are compelling.
Standardization |
Styles produce standardization, which is essential to produce a common look and feel, and to prevent unconstrained style use of styles. |
Single point of change |
Styles provides a single point of change. What do you do when the marketing people decide screen titles should be italic/green this week and bold/blue next week? Using styles simplifies the change, e.g. This week - font-color: green; font-style: italic; Next week - font-color: blue; font-style: bold; |
If by default a style is to be applied to all instances of an eXtension (e.g. we want all buttons to have the same appearance), the style should be applied to the button eXtension template instead of applying the change to each button instance, as this saves you from having to assign a style to individual buttons.
Please refer to FAQ – Customizing eXtensions for more information on how to customize an eXtension template.
Adding a stripe
In our customization plan there is a "bar" or "stripe" across the top of the 5250 screen. After you have added the stripe to the top of your 5250 screen, it will look like this:
Open the Projects Home Page.
Select your project, and then use the Work as Developer option, and sign on to a 5250 session.
Add library AXESDEMO to your library list and call program XHRRPGTRN using the buttons you created in the previous tutorial.
Select one of the displayed employees with an X and press enter. The resulting 5250 screen will look something like this:
You identified this screen as XHRRPGTRN_Maint in a previous tutorial.
Check that the name in the Screen Definition shown on the Screens tab in the Developer window is XHRRPGTRN_Maint.
If the name is not XHRRPGTRN_Maint, or you do not understand why it is XHRRPGTRN_Maint, please complete all the preceding tutorials before going any further in this tutorial.
Click Screen in the Extendable Objects list and then choose Customize Screen from the eXtensions actions button (in the eXtensions bar of the Developer window).
By default, screen XHRRPGTRN_Maint uses the same styles as the basic, un-customized 5250 screens. Since we are going to heavily enhance this screen, you need to ensure the useTerminalStyles property is set to unchecked.
After unchecking the use Terminal Styles property, click the Save button.
You should see your screen change as the BasicFont style takes effect.
Now you are going to change the top of the screen from this:
To this:
Do this by adding a new element to the screen.
Add an eXtension by selecting Simple Stripe from the Extension Toolbox then drag and drop it onto the screen panel.
Change the stripe's context to Mini-Panel Heading.
Move and position the stripe so that it sits below the screen name, above the Department Abbreviation label, and spans the screen width.
The customized screen will look similar to this:
The objective of this task is to change the screen appearance by manipulating screen elements e.g. labels and fields.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed.
The label "Department Abbreviation .." on the 5250 screen can be made shorter.
Click on the label Department Abbreviation to select it and choose Customize Field:
Change the value property to the word Department (the value property is in the Default Visualization).
Now move the label up onto the stripe:
Your screen should show the word Department in the bar at the top left-hand side of the screen.
How to move screen elements
You can move elements around either by dragging them with the mouse or by using the arrow keys (you must select an element before you can move it).
To move multiple elements as a group, draw a box around them (in screen edit mode). Any element that is fully or partially within the box will be selected. All the selected elements can be moved (or sized) together.
The keyboard shortcuts for moving screen elements are:
Right Arrow |
Move to right |
Left Arrow |
Move to left |
Up Arrow |
Move up |
Down Arrow |
Move down |
How to resize screen elements
To resize an element or a group of elements, use the mouse to click on one of the element's sizing handles and drag the element to the size you want.
The objective of this task is to hide the screen identifier.
Click on the screen identifier XHRRPGTRN to select it and choose Customize Field from the eXtensions actions button (in the eXtensions bar of the Developer window).
Uncheck the visible property, then save your changes and unlock the screen.
The screen identifier, XHRRPGTRN, will no longer appear on the screen.
You have now used three essential skills of screen enhancement:
— Simplification or replacement of long text
— Moving screen elements
— Hiding screen elements
Using these skills, you should be able to rearrange the 5250 screen elements so that the top of the screen looks something like this:
Move the business unit label and field, the employee identification label and field, and the screen title into the bar beside department.
The exact location of a customized screen element is visible in its basic style property. You can manually change these values to move elements around the screen.
Sometimes the manual approach is an easier and more accurate way to very precisely align fields.
Applying Styles
The top bar of the 5250 screen now contains three pieces of key information (department, business unit and employee ID), and the screen title. These fields can now be associated with a style to give them their specific visual characteristics.
Click on the department code "ADM" (or whatever code is displayed) to select it.
In the Basic properties, select Default Visualization sheet, and click the Edit button adjacent to the style property.
Select the base style from the dropdown list: KeyInformation
Click OK and save your changes. You can see the effect of the changes.
The color of the Department Abbreviation text has changed to blue. You defined the color when you created the KeyInformation style earlier in this tutorial.
Apply the KeyInformation style to the Business Unit field.
Apply the KeyInformation style to the Employee ID field.
Next, select the screen title and apply the base style as ScreenTitle
The top of the 5250 screen will look similar to this:
The text in the fields is blue and the screen title text is italic.
Using styles will save you time and effort. If you customize 20 screens and then decide that you want to change the screen title text to be italic and blue, you only have to change the style (i.e. the ScreenTitle style), not individual style properties in all 20 screens.
Tooltips
You can add hints or explanations to fields by adding a tooltip. Tooltips provide more meaningful details than a short or abbreviated label.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, click on the Business Unit code, then choose Customize Field and select Tooltip from the Add eXtensions list.
Select the tooltip property in the Basic property sheet, and set it to this text (copy and paste from this):
This code is the business unit that the employee currently works for. It is often referred to as their "BU" code. Their id badges must always display this code or they may be refused admittance to company premises.
This tooltip is just plain text. When you add the text, the property field should have the pencil symbol on the right hand side. The gear symbol will be greyed.
You can change the type of property value you wish to enter by clicking on the gear symbol on the right hand side of the tooltip property. The gear symbol indicates that this property will be evaluated by executing the script that is displayed.
If you want to dynamically create the tooltip by executing a script, then the script you need for this example is:
ENV.returnValue = "This code is the business unit that the employee currently works for. It is often referred to as their \"BU\" code. Their id badges must always display this code or they may be refused admittance to company premises.";
When you hover the mouse over the business unit code, you will now see the tooltip:
Managing long text in tooltips
If you require a lot of text for your tooltips (i.e. hints or explanations), create the tooltips in a word processing tool (e.g. Microsoft Word) where you can perform a spelling and grammar check.
When the text is ready, copy and paste it into your screen definitions, or use CTEXT("Tooltip.0001") type scripting references to externalize the definitions and multilingual translations.
You must use a Unicode capable text editor when editing multilingual strings.
The multilingual section of this tutorial provides more details.
Dates
This task adds a calendar date picker to the date fields.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, double-click Employee Date of Birth, and the add eXtension list window is displayed.
Select Date from the Add eXtension list.
Note:If date field already added uncheck AutoGUI rules of "Top Bar"
Click the Add button and the date eXtension will appear on the screen.
In the date property sheet, change the dateFormatDisplay and the dateFormatServer property values.
dateFormatDisplay |
day d month yyyy |
dateFormatServer |
dd/mm/yy |
The dateFormatServer property must match the format of the date as it appears on the uncustomized screen. We used dd/mm/yy to match the date format shown on the uncustomized screen used in the tutorial. On your machine, the format may be different.
If you cannot find a format that matches the format used to display your dates, you can change the dateFormatServer property to a script, and set it to any valid jQuery date format, using the script:
ENV.returnValue = "dd-mm-y";
See http://docs.jquery.com/UI/Datepicker/formatDate for valid jQuery date formats.
Widen the field to the right so that you can see the full date.
The Employee Date of Birth field is now displayed like this:
The date is displayed in a long format and has a date picker (calendar) that can be invoked by clicking the red calendar icon.
You can control date options using their various properties.
The defaults for the various date formats can be set by changing the global defaults used by the Date eXtension or even programmatically by scripting. You can do this for most properties in most eXtensions. Changing the default value for a property in an eXtension is more efficient than changing the property repeatedly.
Repeat this process for the Employee Start Date and the Termination Date.
Save your screen changes.
After the changes, the screen will look something like this:
Radio Buttons
This task will transform the Employee Gender field into radio buttons.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, double-click Employee Gender and add eXtension window is displayed.
Select Radio Button from the Add eXtension list.
Click the Add button.
aXes will insert a radio button extension and the screen will look like this:
Next, we need a value for each radio button.
Radio button values can be created from multiple types of input sources. In this case, we are going to use the simplest source, a table of fixed values.
Look at radio button property sheet:
Change the value of the dataSourceType property to Fixed Values. Change the value of the orientation property from vertical to Horizontal. Then, click the Edit Items button adjacent to the fixedValues property. The Edit Items window will appear where you will define a value and label text for each radio button. |
The empty Edit Items window looks like this:
The value determines what will be checked for and put into the 5250 entry field by the radio button. The label text determines what is displayed beside the radio button.
Click the plus button [+] in the Edit Items window and add two items:
Item |
Value |
Text |
1 |
Male |
Man |
2 |
Female |
Woman |
After you finish the Edit Item windows should look like this:
Click OK to close the Edit Items window.
Your screen should look something like this:
Drop down lists
This task will transform the State and Country fields into drop downs (i.e. list boxes).
The data used to fill drop downs can come from static tables, dynamic tables (created by SQL commands), XML documents, or simple static lists.
A separate tutorial covers the possibilities for supplying data to fill drop down lists and ways that you can use them.
In this tutorial you are going to use server based static tables shipped with aXes as the data source for the drop down lists.
State field drop down
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, double-click State, and an add eXtensionv window is displayed.
Select Dropdown from the Add eXtension list.
aXes will insert a dropdown extension and the screen will look like this:
Next, we need to define a data source type and a data source.
Look at the dropdown property sheet:
Change the value of the dataSourceType property to Static Table. Change the value of the tableName propertyto USState. Widen the state field on the 5250 screen so that the state names fit in the window width. Save your changes. |
Your screen will now show a state code drop down like this:
Country field drop down
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, double-click Country, and add eXtension window is displayed.
aXes will insert a dropdown extension.
On the dropdown property sheet, change the value of the dataSourceType property to Static Table.
Change the value of the tableName property to ISOCountry (the table name is case sensitive, so ensure you use the exact spelling and upper and lower case).
Widen the state field on the 5250 screen so that the country names fit in the window width.
Dropdowns have many options for sources of data, presenting the data, and can initiate actions when a user selects a drop down item. Using these features drop downs can be used to achieve clever and useful screen interactions. For example, imagine you want the country drop down to show the country code and the full name of the country.
Put the screen in edit mode and select the country code drop down.
Click the Edit Script button adjacent to the onFillDropDown property. |
Copy this code into the Edit Script window.
ROW.value + " (" + ROW.text + ")"
The Country drop down will now look like this:
As you may imagine, this ability to script what happens as the drop down is filled and what happens when a user selects an item can be used in many clever and useful ways.
Using ROW and other scripting objects
In the preceding example the ROW scripting object was used. In scripts that process table information, it is shorthand scripting used to refer to the "current" ROW in the table.
There are other shorthand objects you can use in your scripting:
Objects |
Description |
Example of Common Methods |
FIELD |
The specific field bound to the extension. |
FIELD.getValue() FIELD.setValue("ADM") |
FIELDS |
Gets a reference to any named field on the current screen. |
FIELDS(“CustomerName”).getValue() |
CTEXT |
Shortcut for TEXT.cust |
CTEXT(“label001”). Retrieves the customer text associated with the key value "label001". |
SENDKEY |
Send key |
SENDKEY(“Enter”) SENDKEY("F4") |
TRACE |
Traces values into the trace window. |
TRACE("Button 1 clicked") |
DEBUG |
Shortcut for AXES.Debug.output |
LANGUAGE |
Current language code |
Push Buttons
This task will hide the function keys and replace them with push buttons.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, select Push Button from the Extension Toolbox then drag and drop it onto the screen panel.
Repeat these steps, selecting then dragging and dropping Push Button onto the screen, until you have three push buttons.
Select each button in turn and edit the script for the caption and onClick properties.
First Button |
caption |
CTEXT("Save Changes"); |
onClick |
SENDKEY("Enter"); |
Second Button |
caption |
CTEXT("Cancel Changes"); |
onClick |
SENDKEY("F12"); |
Third Button |
caption |
CTEXT("Delete All Details"); |
onClick |
SENDKEY("F22"); |
Click the Edit Script button adjacent to the property to open the Edit Script window. You can copy and paste the script from the table above.
This is an example of editing the script for the caption property of the Save Changes button.
Move the buttons to the bottom right-hand side of the screen.
Select the F12=Cancel object and hide it by unchecking its visible property.
Select the F22=Delete object and hide it by unchecking its visible property.
Your screen will look like this:
The F12=Cancel and F22=Delete text at the bottom of the 5250 screen is screen text, just like the text "Employee Title". There is nothing special at all about this text. Its presence or absence in no way influences what function keys are actually enabled by the screen.
The Save button was added for the Enter function key. In most good GUI designs all function keys generally have an associated button.
Multi-lingual text
If you are not concerned about multi-lingual applications, skip to the next section.
You can use multi-lingual text for buttons, tooltips, labels, etc.
You must use a Unicode capable text editor when editing multi-lingual text. Almost all PC based text editors recognize and can handle Unicode files.
Typically, you can check this by looking at the “Save as” dialog options. For example, Notepad shows this in the Encoding option.
When you added the Save Changes button, you used the script, CTEXT("Save Changes"); to set the button's caption. This indicates that the button's caption is found by executing the CTEXT("Save Changes") scripting function.
The CTEXT() function looks up the customer multi-lingual text for the key "Save Changes" and returns the associated language text.
Customer multi-lingual text is stored in the Texts_Cust_LL.txt file. The LL represents a language code, e.g. English is en, French is fr, German is de, and Japanese is ja. The name of the multi-lingual text file for Japanese is Texts_Cust_ja.txt.
At execution time CTEXT("key") looks up the key supplied and returns a value from data loaded from the current language file. If no entry is found, the "key" is returned as the string.
See the deployment tutorial for more details about using multi-lingual text.
The technique of using CTEXT("key") for multilingual text can and should be used for literal text values everywhere in eXtensions intended for use in multi-lingual applications.
The choice of the CTEXT "key" here makes the button captions correct even when there are no key values in the Texts_Cust_LL.txt files. This is because the key and the English translations are the same values.
This approach is fine with short to medium text strings, but using CTEXT("Enter your password or click cancel to cancel and then log on again") would be not be advisable.
You should probably look to developing a "key" naming standard like CTEXT("Message_0001") or CTEXT("LongString.001") instead. This means that you have to provide English (or native) language translations of what Message_0001 (say) translates to.
If you change a Texts_Cust_LL.txt file you should clear your browser cache to pick up the new file version.
Group boxes
This task will rearrange data on the 5250 screen into groups.
With the aXes Developer window and the XHRRPGTRN_Maint screen displayed, select Group Box from the Extension Toolbox then drag and drop it onto the screen panel.
Look at the Group Box property sheet:
Change the value of the caption property to Identification. Change the value of the look property from Classic to Modern. Save your changes. |
Tip: we can tell the group box to always use the Modern look by modifying the group box eXtension template. This way we don’t need to adjust the look property for each group box we add.
Move the group box under the title bar, leaving a small gap, and approximately size it according to the about half the width of the screen plan.
Now, move the employee identification information according to the plan. The employee identification information is title, last name, first name and gender. After you finish your screen should look something like this:
Add another group box and set its caption as Important Dates, and the look property to Modern, and move it to the right-hand side of the Identification group box.
Change the Employee Date of Birth label to Birth.
Change the Employee Start Date label to Start.
Change the Termination Date label to Termination.
Then arrange the date information according to the overall screen plan, something along these lines:
Add another group box labelled Location and Job Details, and the look property to Modern, and position it on the left-hand side of the screen below the Identification group box.
After you finish the group box will look like this. |
Move these fields into the group box: Street City State Zip (Postal Code) Country Phone (Employee Telephone) Job Title Salary (Employee Annual Salary) Start Action |
Do not obsess over the exact layout. You may notice that this layout is slightly different from the original.
Images
This task will add an image to the 5250 screen. You may notice that the image is not part of the original 5250 screen.
Change the group box caption to Photo, and the look property to Modern, and move it to the right-hand side of the Location and Job Details group box.
Add another extension by selecting Image from the Extension Toolbox, then drag and drop it onto the screen panel.
Select the image eXtension.
Change the imagePath property to /ts/skins/images.
Change the imageName property to examplephoto.gif.
The image will appear in the Photo group box.
The image may appear to be very large. This is because the image appears as its full size. To shrink the image to the desired size, we need to change the height and width properties so that the browser will render the image to fit inside its container. |
Click the Edit Style button in the style property of the image extension.
height: 100%
width: 100%
This will ensure the image fits inside the Photo group box and not extend beyond the group box borders.
The completed screen will look similar to this:
The ability to script the image properties is useful. Often the image name needs to be dynamically determined by using information present on the screen, such as a product number or an employee number. You may even have to execute an SQL request to look up a database table to find the name of the image.
Hyperlinks
This task will add hyperlinks to the 5250 screen.
Change the group box caption to Online Documents, and move it to the right-hand side of the Photo group box.
Add another extension by selecting HyperLink from the Extension Toolbox then drag and drop it onto the screen panel, then change the caption to Employment Contract, and move it into the Online Documents group box.
There is a small problem here. Since we don’t want the text to wrap around on two lines the font size needs to be reduced. You can do this in two ways:
Option 1: |
Change the style font-size of the hyperlink to 7pt or 8pt |
Option 2: |
Define a new application-wide style named SmallHyperLink (say) that defines and standardizes the visual characteristics of a small hyperlink. |
If you choose option 1, you will have to change the font-size for every small hyperlink.
If you choose option 2, you need to edit your application properties and define a new style with properties, something like this:
name |
SmallHyperLink |
styleFor |
HTML Element |
htmlTag |
a |
style |
font-size: 7pt; |
Refer to the earlier section in this tutorial describing how to create styles.
Edit the style property of the Employment Contract hyperlink.
Input the following into the Edit Styles window, then click OK: cursor: Hand
Next, you need to specify what happens when a user clicks the hyperlink.
Edit the script for the onClick property of the Employment Contract hyperlink, and copy the this code into the Edit Script window, then click OK.
window.open('/ts/skins/images/examplecontract.pdf','_blank');
When clicked, the Employment Contract hyperlink will open a PDF document.
Add another HyperLink extension.
Move the hyperlink into the Online Documents group box and change its caption to Latest Time Sheet.
Edit the style property of the Latest Time Sheet hyperlink and input the following into the Edit Styles window, then click OK.
cursor: hand;
Edit the script for the onClick property of the Latest Time Sheet hyperlink, and copy the this code into the Edit Script window, then click OK.
window.open('/ts/skins/images/exampletimesheet.xls','_blank');
When clicked, the Latest Time Sheet hyperlink will open an Excel workbook.
This task will add one more group box to the 5250.
Change the value of the caption property to Actions.
Change the value of the look property to Modern.
The finished screen will look something like this:
This screen is not exactly the same as the original plan as some minor improvements have been made along the way.
Always test your customizations as a user.
You can test your screen customizations while logged on to aXes as a developer, but you must always also test your application while logged on as a user.
To test as a user, open the Projects Home Page.
Select your project, and then use the Work as a User (aXes-TS2) option to start aXes.
Verify that the customizations display correctly, try out the buttons and hyperlinks.
