Contents
1.1. Define two static tables, the Popularity Table (now) and Popularity Table (previous): 1
1.2. Add a Google chart extension and set the following properties: 1
1.3. Add the following script to the options property: 1
1.4. After clicking the OK button in the edit script dialog, the chart extension immediately will become a chart: 1
2.1. Add a Google chart extension and set the following properties: 1
2.2. Add the following script (or an equivalent) to the arrayData property: 1
2.3. Add the following script to the options property: 1
2.4. After clicking the OK button in the edit script dialog, the chart extension immediately will become: 1
3.1. Add a Google chart extension and set the following properties: 1
3.2. Add the following script to the options property: 1
3.3. Add the following script to the tableScript property: 1
3.4. After clicking the OK button in the edit script dialog, the chart extension immediately will become: 1
4.1. Add a Google chart extension and set the following properties: 1
4.2. Add the following string to the url property: 1
4.3. Add the following string to the options property: 1
4.4. After clicking the OK button in the edit script dialog, the chart extension immediately will become: 1
5.1. Add a Google chart extension and set the following properties: 1
5.2. Add the following script to the options property: 1
5.3. Add the following script to the arrayData property: 1
5.4 Check the noColumnLabel property: 1
6.1 Check or enable the draggable property: 1
6.2 Check or enable the dragHandle property: 1
6.3 Set the dragHandleOrientation property to: 1
6.4 Set the script of the dragHandleVariable property to: 1
URLs. 1
  Note that the columnOrder property should be:
       ENV.returnValue = ["name", "fame"];
1.4. After clicking the OK button in the edit script dialog, the chart extension immediately will become:
(Static Table data which generated the Diff chart is courtesy of Google.)
The resulting chart is a rendering of a bar graph showing the current and the previous popularity data of persons.
As for the usage of the XML file data source, just like in the dropdown extension, the user of an Axes developer would depend on the XML filename and the directory where the file resides.
Also, in the documentation of the dropdown extension, there is a data source type called “Fixed Values”. In this extension, the same thing is called “Fixed Array (Google Array Format)” and “Fixed Table (Google DataTable Script)”; these 2 new data source types are of Google’s flavour because this extension is bound to follow Google’s rules.
According to the Google developer website
    https://developers.google.com/chart/interactive/docs/datatables_dataviews#arraytodatatable
an array in the format of
    [ <row 1 data>, <row 2 data>, <row 3 data>… <row N data> ]
where a row data represents a table row, will produce a graph if this array is passed as a parameter to the
    google.visualization.arrayToDataTable()
API and the resulting value is passed as the data parameter to the chart() API of an instantiated chart object.
An example illustrating the usage for the fixed array data source is given in the following steps.
      ENV.returnValue = [
                  [ "地名", "テキスト" ],
                  [ "秦野駅", "地元!!!" ],
                  [ "東武練馬駅", "自宅!!!" ],
                  [ "浅草橋3-1-8", "職場!!!" ]
  Note that the texts in the script follow the <place, comment> row format. Hence, to create data for a more general audience, specific values can be made in the form of
     [ [“name of place”, “comment”],
       [place #1, comment #1],
       [place #2, comment #2],
       [place #3, comment #3] ]
replacing places and comments with actual place names and remark texts in quotes.
       ENV.returnValue = {
                mapType: ‘normal’,
                 showTip: true
The chart shows a map in Japan with red markers to the 3 place names just defined in the arrayData property.
Note: Set the zoom setting in the upper-right hand corner of the screen to 100% to be able to display the tooltip when mouse is hover on the red marker.
As for the fixed table data source type, according to the Google website
    https://developers.google.com/chart/interactive/docs/datatables_dataviews#emptytable
a DataTable object can be instantiated, column names and types can be defined, and the object data can be populated in a scripting manner. Thus, this DataTable object becomes the data source for this type.
An example illustrating the usage for the fixed table data source is given in the following steps.
ENV.returnValue = {
    "sankey": {
        "node":
            "colors": [ "#a6cee3", "#b2df8a", "#fb9a99", "#fdbf6f", "#cab2d6", "#ffff99", "#1f78b4", "#33a02c" ],
            "label" : { "bold": true, "color": "#871b47", "fontName": "Times-Roman", "fontSize": 14, "italic": true }
        "link":
            "colorMode": "gradient",
var data = new google.visualization.DataTable();
data.addColumn( 'string', 'From' );
data.addColumn( 'string', 'To' );
data.addColumn( 'number', 'Weight' );
data.addRows(
[ 'Brazil',       'Portugal',     5 ],
[ 'Brazil',       'France',       1 ],
[ 'Brazil',       'Spain',        1 ],
[ 'Brazil',       'England',      1 ],
[ 'Canada',       'Portugal',     1 ],
[ 'Canada',       'France',       5 ],
[ 'Canada',       'England',      1 ],
[ 'Mexico',       'Portugal',     1 ],
[ 'Mexico',       'France',       1 ],
[ 'Mexico',       'Spain',        5 ],
[ 'Mexico',       'England',      1 ],
[ 'USA',          'Portugal',     1 ],
[ 'USA',          'France',       1 ],
[ 'USA',          'Spain',        1 ],
[ 'USA',          'England',      5 ],
[ 'Portugal',     'Angola',       2 ],
[ 'Portugal',     'Senegal',      1 ],
[ 'Portugal',     'Morocco',      1 ],
[ 'Portugal',     'South Africa', 3 ],
[ 'France',       'Angola',       1 ],
[ 'France',       'Senegal',      3 ],
[ 'France',       'Mali',         3 ],
[ 'France',       'Morocco',      3 ],
[ 'France',       'South Africa', 1 ],
[ 'Spain',        'Senegal',      1 ],
[ 'Spain',        'Morocco',      3 ],
[ 'Spain',        'South Africa', 1 ],
[ 'England',      'Angola',       1 ],
[ 'England',      'Senegal',      1 ],
[ 'England',      'Morocco',      2 ],
[ 'England',      'South Africa', 7 ],
[ 'South Africa', 'China',        5 ],
[ 'South Africa', 'India',        1 ],
[ 'South Africa', 'Japan',        3 ],
[ 'Angola',       'China',        5 ],
[ 'Angola',       'India',        1 ],
[ 'Angola',       'Japan',        3 ],
[ 'Senegal',      'China',        5 ],
[ 'Senegal',      'India',        1 ],
[ 'Senegal',      'Japan',        3 ],
[ 'Mali',         'China',        5 ],
[ 'Mali',         'India',        1 ],
[ 'Mali',         'Japan',        3 ],
[ 'Morocco',      'China',        5 ],
[ 'Morocco',      'India',        1 ],
[ 'Morocco',      'Japan',        3 ]
ENV.returnValue = data;
(Fixed Table script which generated the Sankey chart is courtesy of Google.)
A backgrounder from Google:
A sankey diagram is a visualization used to depict a flow from one set of values to another. The things being connected are called nodes and the connections are called links. Sankeys are best used when you want to show a many-to-many mapping between two domains (e.g., universities and majors) or multiple paths through a set of stages (for instance, Google Analytics uses sankeys to show how traffic flows from pages to other pages on your web site).
For the curious, they're named after Captain Sankey, who created a diagram of steam engine efficiency that used arrows having widths proportional to heat loss.
Another new data source type that is introduced to Axes in this extension is the usage for the Google Data Query. In this usage, a user of the Axes developer only needs to define a URL and a query string for a known datasource web service.
An example illustrating this usage is given in the following steps.
queryString: SELECT A,D WHERE D > 100 ORDER BY D
     http://spreadsheets.google.com/tq?key=pCQbetd-CptGXxxQIG7VFIQ&pub=1
ENV.returnValue = {
    legend: 'top',
    hAxis:
           slantedText: true
(Values for the url and the queryString properties which generated the Line chart is courtesy of Google.)
  The chart above shows the population density. So, if the datasource web service in this example updates their data instantaneously, that means that the extension is displaying a graph with real-time data.
Note: Set the zoom setting in the upper-right hand corner of the screen to 100% to be able to display the tooltip when mouse is hover on the point in the chart.
arrayData2, directory2, filename2, queryString2, sqlVariable2, tableFilename2, tableName2, tableScript2, url2 properties
The illustration in example 1 which explains how to use the static table data source type gives a hint on the usage of the tableName2 property. And in the example, the chartType value is “Diff Chart”. Therefore, the usage for the other properties which are arrayData2, directory2, filename2, queryString2, sqlVariable2, tableFilename2, tableScript2, and url2 will have meaning only when the chartType value is also “Diff Chart”. The arrayData2 property is the counterpart of the arrayData property when the data source type is “Fixed Array (Google Array Format)”, and so on and so forth…
The columnOrder property is applicable when the data source type is “Dynamic Table”, “Static Table”, or “XML File”. The purpose of this property is to allow the user to identify which column data is first, which is next to it, etc., because the extension has no way to know which is which. If this is not specified, the extension will default to the alphabetical order of column names.
Revisiting the example 1 about the usage for the static table data source type, note that the “name” and the “popularity” labels defined in the static tables from step 1.1 can be assigned arbitrarily by the user. With a wrong column name ordering, this may lead to error in chart rendering which cannot be debugged at the extension level.
To illustrate this scenario, change all the “popularity” string to “fame” in the 2 tables. The new table definitions will become:
Save and close the file; reload the project. The new rendering of the chart extension will become:
To rectify this situation, there is a need to adjust the label ordering by setting the columnOrder property to:
This means that the “name” string is set as the first column label, and the “fame” as the next column label. If the “fame” label is set as the first column label, for example,
     [ “fame”, “name” ],
it will lead to the same rendering error shown previously, popping the “First column must be a domain column” message, since the columnOrder property is not specified and the default behaviour is to sort out the columns names resulting to an array with “fame” as the first element.
After clicking the OK button in the edit script dialog, the chart extension immediately will result to the expected output:
Notice that the legend name representing the blue bar is changed from “popularity” to “fame”.
The noColumnLabel property is applicable when the data source type is “Fixed Array (Google Array Format)”, or “Static Table”. With these data sources, a user can define an array data where the first row is actually a row data which do not represent column labels. Checking this property lets the extension know that this is the case.
An example illustrating the noColumnLabel property is given in the following steps.
     ENV.returnValue = [
          [ "Mon", 20, 28, 38, 45 ],
          [ "Tue", 31, 38, 55, 66 ],
          [ "Wed", 50, 55, 77, 80 ],
          [ "Thu", 77, 77, 66, 50 ],
          [ "Fri", 68, 66, 22, 15 ]
Click the OK button in the edit script dialog above, and unlock the screen to show the output, the chart extension will display:
The reason for this error is that, in the array values just set to arrayData property, the first row data is of the same kind with the rest of the data. In other words, it does not represent the column labels. To correct the situation, simply
and immediately, the chart extension will become:
(Fixed array values which generated the Candlestick chart is courtesy of Google.)
A candlestick chart is used to show an opening and closing value overlaid on top of a total variance. Candlestick charts are often used to show stock value behavior. In this chart, items where the opening value is less than the closing value (a gain) are drawn as filled boxes, and items where the opening value is more than the closing value (a loss) are drawn as hollow boxes.
options property
The options property is the key to the styling of a Google Visualization chart. Familiarize each of the charts to learn what properties and behaviour that are applicable to each one.
draggable, dragHandle, dragHandleOrientation, dragHandleVariable properties
The draggable property enables the placement of the extension be changed by mouse movement.
If a user wants the extension to be moved only by dragging in a specific portion of it, then the dragHandle property should be set. With a checked dragHandle property, the user is given a default drag handle with a given characteristics:
    - light-blue color
    - size of 20px by 50px (height x width)
    - offset margin of 10px both from the top side and from the right side
These characteristics is modifiable by changing the values of the dragHandleVariable property.
The dragHandleOrientation property which has a default value of “Top-Right” can also be set to other values which are:
    “Top”, “Top-Left”, “Right”, “Bottom-Right”, “Bottom”, “Bottom-Left”, “Left”, “Center”,
    “User-Defined”
The reason for the drag handle is because there are some charts which allow browsing to its content portions. A good example is the map. By dragging a portion of the map, browsing to the other map coordinates not shown previously is possible without moving the chart position. Without this drag handle, map browsing cannot be done when the draggable property is checked or enabled.
As an illustration for the dragHandle property, revisit the map project in example 2. Dragging a map portion will change the view to other coordinates depending on the direction of the dragging action.
Immediately, the dragHandle property will be added to the extension property pane.
Dragging a map portion gives a different result at this time because the whole chart area will be moved. Since this new behaviour is not the desired output,
Immediately, 2 complimentary properties, namely, dragHandleOrientation and dragHandleVariable, will be added to the extension property pane.
Simultaneously, the chart extension will become:
The added portion in light-blue color inside the chart extension is how the default drag handle looks like. Moving the mouse icon to the light-blue area will turn it from the grab icon  to the move icon . Dragging from the drag handle area will move the whole chart extension. Dragging from other portions of the map will allow browsing to the rest of map coordinates.
Clicking the OK button of the edit script dialog, the chart extension immediately will become:
The characteristics of the drag handle becomes yellow in color, 50px by 30px in size, and (190px, 140px) in (left, top) location. Hovering the mouse to the drag handle area will turn the grab icon  to the cell icon .
In the dragHandleVariable property variable there are 4 offset margin parameters, namely, bottomOffset, leftOffset, rightOffset and topOffset. Listed below are the dependencies of these parameters to the values of the dragHandleOrientation property.
    Top              : topOffset
    Top-Left       : leftOffset, topOffset
    Right            : rightOffset
    Bottom-Right: bottomOffset, rightOffset
    Bottom         : bottomOffset
    Bottom-Left  : bottomOffset, leftOffset
    Left              : leftOffset
    Center          : none
    User-Defined : leftOffset, topOffset
This means that only parameters with dependencies will have effect on the setting of the dragHandleOrientation property. Notice that there is no dependency with the “Center” as value for the dragHandleOrientation property simply because there is only one center location. Note that setting the value of the dragHandleOrientation property from Top-Left to User-Defined (or vise versa) have no significant effect because both have the same dependency parameters which are leftOffset and topOffset.
URLs
Google Visualization Charts
Terms of Service:
    https://developers.google.com/chart/terms
Google Array Format
DataTable Scripting
draw() API
    https://developers.google.com/chart/interactive/docs/drawing_charts#chart.draw
computeDiff() API
    https://developers.google.com/chart/interactive/docs/gallery/diffchart
