About this tutorial
Objectives
This tutorial teaches you how to apply styles.
Prerequisites
Tutorial 2 -  Screen and Field Identification
Before attempting this tutorial, please complete all of the steps in Tutorial 2.
Outline
Default Directories
Application Level Styles
How to set Application Styles (Group Box header)
Function Keys
Basic Font
Input Field
Centre Screen Content
Outer Div Style (Centred Content)
Menus
Dropdown Box
Popups
Text Box
Subfile Header
Subfile Body
Datatable - Download Button Panel
Datatable - Download Buttons
Application Background Image/Color
Default Directories
Note: The directories, images, and files used are based on a specific install of aXes. You will need to change these based on your own project.
Image path
   /ts/skins/images
Install Path for aXesJSM
   /axes421jsm/jsm/instance/www/instance/htdocs/ts
Web route directory aXesJSM
Install Path for aXesW3(older version of aXes)
   /axes421/ts
Web route directory aXesW3 (older version of aXes)
   /axes421/
  1. How to set Application Styles (Group Box header)
  2. This technique allows you to change the header style for the group box extension.
    1. Define a new Application style with a meaningful name. For example, ‘Card Header’
    2. Set the ‘styleFor’ property to ‘HTML element’
    3. For the class set it to ‘.md-card__header’
    4. Note: There are two underscores between card and header.
    5. Edit the Application Styles and set the following attributes:
    6.  Background-colour: !important
       Height: 15px
       min-Height: 15px!important
      Note: In this case, ‘!important’ overrides the Material Design style, which is applied to the group box header.
    7. Save your changes. The group box header will now pick up the new style.
  3. Function Keys
  4.  Name:         FButtonStyle
     StyleFor:     HTMLElment
     htmlTag:     button[id^="fkeyPanel-button"]
     Style:           Font-Size: larger!important
                         Background-Color: #oob050!important
                         Color: #ffff00!important
  5. Basic Font
  6.  Name:         Basic Font
     htmlTag:     dummy, div#terminalContent *:not(.material-icons):not(.mdc- floating-label--float-above)
     Style:           Font-Size: 10
                         Font-Family: Verdana (non-proportional fonts: Lucida Console, Serif, monospace, Courier New)
                         Color: #c0504d
  7. Input Field
  8.  Name:         InputFieldBGrnd
     htmlTag:     div.mdc-text-field
     Style:           Background-Color: #fdeada!important
  9. Centre Screen Content
  10.  Name:         CentreContent
     htmlTag:     dummy, div#terminalInner
     Style:           Border-Left-Color: transparent
                         Border-Left-Style: Solid
                         Border-Left-Width: 1px
                         Border-Right-Color: transparent
                         Border-Right-Style: solid
                         Border-Right-Width: 1px
                         Margin-Left: auto
                         Margin-Right: auto
                         Width: 70%
  11. Outer Div Style (Centred Content)
  12.  Name:         OuterDivBackground
     htmlTag:     dummy, div#terminalOuter
     Style:           Background-Color: #DD9D2B
  13. Menus
  14.  Name:         Menu Style
     htmlTag:     #terminalContent .ax-terminal-5250menuitem span
     Style:           Color: #1F497D
  15. Dropdown Box
  16.  Name:         DropdownBox
     htmlTag:     Select
                         Background-Image: url(/ts/skins/images/other/blue/large/down-arrow_outline.png )
                         Background-Origin: Padding-box
                         Background-Position: right center
                         Background-Repeat: no-repeat
                         Background-Size: 16px 16px
  17. Popups
  18.  Name:         PopupStyle
     htmlTag:     #win1.ax-terminal-window
  19. Text Box
  20.  Name:         textbox
     htmlTag:     div.mdc-notched-outline__idle, div.mdc-notched-outline
     Style:           Border-Color: white!important
  21. Subfile Header
  22.  Name:         Subfile Header
     htmlTag:     div.md-sftable-header--full
  23. Subfile Body
  24.  Name:         Subfile Body
     htmlTag:     div.md-sftable--full
     Style:           Background-Color: #d99694
  25. Datatable - Download Button Panel
  26.  Name:         Download Button Panel
     htmlTag:     div.dt-buttons.ui-buttonset
  27. Datatable - Download Buttons
  28.  Name:         Download Buttons
     htmlTag:     button.dt-button,div.dt-button,a.dt-button,span.ui-button-text
     Style:           Font-Size: smaller
                         Height: 30px
                         Padding: 0px
  29. Application Background Image/Color
  30.  Name:         Background Image
     StyleFor:     Application Window
     Style:     Background-Color: #oob050
                         Background-Image: url(/ts/ts2/css/images/) !Important
                         Background-Origin: padding-box
                         Background-Size: 100% 100%
