axScreenDataTable
axScreenDataTable allows to embed a datatable into your screen. With axScreenDataTable , multiple pages of subfile records can be loaded into the screen datatable therefore allowing the user to view more records at the same time. Using the properties described below, the user can customize how the subfile records can be loaded.
By using this extension you will be subject to the Terms of Service as outlined in https://datatables.net/faqs/index#Licensing
headerHeightRows
The number of rows in the subfile header.
Yes. Must be 1 - 24
1
autoWidth control DataTables' smart column width handling No False
baseStyle
Set base style using avaialable base style for datatable (display, hover,compact,stripe,order-column)
display hover compact stripe order-column.
bodyFirstRow
The first row of the subfile body. If 0, this means automatically determine the first row of the subfile body.
Yes. Must be 1 - 24
0
bodyLastRow
The last row of the subfile body. If 0, this means automatically determine the last row of the subfile body.
Yes. Must be 1 - 24
0
buttons
Define the buttons to show in the Datatable. Values can be 'copy', 'pdf', 'excel'
Yes. Must retun an array of String.
ENV.returnValue = [];
columnDefs
Column definitions
ENV.returnValue=[];
columnFirst
The first column of the subfile
1
columnLast
The last column of the subfile
79
dom
Define the table control elements to appear on the page and in what order.
Blftip
initialNoOfPages
The number of pages that will be loaded on the first display of the screen.
1
language Language configuration options for DataTables Yes ENV.returnValue = [];
lengthChange control the end user's ability to change the paging display length of the table. No False
lengthMenu Change the options in the page length select list. Yes ENV.returnValue = [ 10, 25, 50, 75, 100 ];
linesPerRow
The number of screen lines that represent a row in the subfile. A value of 0 tells the eXtension to attempt to automatically determine the value.
0
loadFromFirstPage
Indicates whether to load from the first page when the current page in the screen is not the first page.
False
order Initial order (sort) to apply to the table. Yes ENV.returnValue = [];
ordering control ordering (sorting) abilities in DataTables. No. False
paging Enable or disable table pagination. No False
removeBlankColumns Automatically remove blank or space only column No True
searching control search (filtering) abilities No False
showinfo Show information No False
To use this extension you must be familiar with Datatables. Information about Datatables can be found at: https://datatables.net/
