About this tutorial
Objectives
In this tutorial, you will learn about checking your PC and browser requirements, verifying your aXes installation and setting up a project.
Prerequisites
Successful aXes installation
Outline
Check development PC
Check Internet Explorer settings
Check aXes demo library and server settings
Set up a project
Check your development PC is ready
To do application development using eXtensions you need to have an up to date development PC. Complete this checklist:
PC Check List
Notes
Core 2 Duo class processor, equivalent or better with 2Gb RAM or more
You can use eXtensions on systems below this recommended specification, but your development activities will be impacted accordingly. You should consider upgrading your development system.
Screen resolution of 1440×1080 or better
There are productivity and ease of use benefits to be gained by using a wide screen monitor or multiple side-by-side monitors when doing any type of IT application development. Any form of IT application development on a low-resolution monitor (eg: 1024x768) will take longer and be more cumbersome than it needs to be.
Windows 8 or later.
A supported browser.
Firefox (latest version), Chrome (latest version), Internet Explorer Version 11
Check your Internet Explorer settings
To do aXes application development you may want to use Internet Explorer 11.
Complete this Internet Explorer checklist if you do. This is not required if you are using another supported browser.
Internet Explorer Check List
Check that Internet Explorer's SmartScreen Filter is turned off.
Use the Safety button to view the status of your Internet Explorer SmartScreen Filter. If it is turned on then turn it off.
The off setting is strongly recommended for application developers to avoid Internet Explorer failures.
Check that the aXes server is in your trusted sites list.
Open your browser. Use Tools -> Internet Options -> Security tab.
Select Trusted sites, and click the Sites button.
In this example http://lansa04 is the aXes server root address, so it was added:
In order to see the changes you make immediately, ensure that you are not using cached pages. To do this, click on the Settings button in the browsing history section of the General tab, and then select the option to check for newer versions of stored pages, every time I visit the webpage:
Check that any pop up blocker(s) you have installed do not block pop ups initiated by scripts loaded from your aXes server.
Check that library AXESDEMO is installed and useable
To complete the eXtensions tutorials you must have library AXESDEMO installed on your system.
The aXes demonstration material is installed by option 99 during an aXes install.
Perform this check before starting any eXtensions tutorials:
Check for AXESDEMO Library
Sign on to a 5250 screen.
Run the command ADDLIBLE AXESDEMO
Run the command CALL XHRRPGTRN
The resulting 5250 display should look like this:
The eXtensions tutorials will use these objects from the AXESDEMO library:
Object
Type
Comment
XHRRPGTRN
*PGM
5250 Employee Maintenance Program
XHRRPGTRND
*DSPF
Display file used by program XHRRPGTRN
XHRBU
*PF
Physical file of Business Units
XHRBU01
*LF
View of Business Units
XHRDEPT
*PF
Physical file of Departments
XHREMPTN
*PF
Physical file of Employees
XHREMPTN01
*LF
View of Employees
XHREMPTN02
*LF
View of Employees
Check your aXes Server settings
Check aXes HTTP Server Settings
Locate your aXes HTTPD.XML configuration file.
Typically, it is located in folder /axesjsm/jsm/instance/system and named httpd.xml
Locate the directive <parameter name="device.system.name" value="YOUR SYSTEM NAME"/>
Replace "YOUR SYSTEM NAME" with your server name. For instance AXESDEMO
Set up an eXtensions project
Create a new short cut onto your workstation's desktop:
Location
http://<your aXes host>:port
aXes Home Page
Replacing <your aXes host> with the appropriate IP address and port number. For example: http://lansa14:9423
Use the new shortcut to open the aXes Home Page. Click on Developer Tools in the top bar.
When requested, enter the aXes developer user profile and password.
The shipped defaults are,
User Name: dev
Password: dev
You should change these default values. Refer to the link below for more information
Change the default password for developer tools projects
The aXes Projects List should now be displayed, something like this:
Decide on a unique name for your aXes project.
Your chosen project name should be short and consist of only letters from the English alphabet and numbers. For example, MyProject1 or PaulProject2 would be good names. If existing projects are shown in the list on the right, use a name for your new project that is not already shown in the list.
Click on the Create a new Project … option.
The resulting display should look like this:
Note the warning about backing up your IFS project folders.
Enter a name and description for your project.
Do not check VLF-ONE RAMP project tick box.
Then click the Create Project button.
A message like this should appear:
Close the Projects Home Page now.
While learning to use eXtensions is it common to have a private or personal project. However, when working on a real project you should create just a single project that all the developers on the project work within. Projects are discrete entities and cannot be merged.
You have completed this tutorial and are ready to start the next tutorial.
